KB89014
Published: May 20, 2020
Can't run PAC Control Node-RED nodes or REST API; -401 error
Firmware for GRV-EPIC-PR1
2.0.0
2.0.1
When you run a Node-RED flow with PAC Control Nodes or use the PAC Control REST APIs, you receive the following error: PAC error -401. Unable to authorize transaction.
Contact Product Support to obtain a beta version of firmware that resolves this issue.
