KB89005
Published: June 9, 2020
MQTT with Broker Using SSL does not Publish Topics
Firmware for GRV-EPIC-PR1
All versions prior to 2.0.1
2.0.1
If you configure MQTT with a broker that uses SSL, the configuration will save successfully, but the topics do not get published.
