KB88995
Published: July 22, 2020
9-bit Addressing Mode Does Not Work
Firmware for  GRV-EPIC-PR1
All versions prior to 2.0.2
2.0.2
In PAC Control, when using a GRV-CSERI-4 module, if you configure a serial communication handle with parity=9, the parity is not set correctly.
