KB88970
Published: July 9, 2020
Revision: 4.0
PAC Control Command Move Numeric Table To I/O Unit Ex may move wrong number of points
Firmware for:
  • GRV-EPIC-PR1
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
For GRV-EPIC-PR1 firmware: all versions through 2.0.0
For PAC Firmware: All versions prior to 10.3b
For GRV-EPIC-PR1 firmware: 2.0.1
For PAC firmware: 10.3b
For the following commands, if you specify -1 for the Points per Module parameter (Argument 3), PAC Control runs the non-Ex version of the command:
  • Move Numeric Table To I/O Unit Ex
  • IVAL Move Numeric Table To I/O Unit Ex
Do not assign -1 to the Points per Module parameter (Argument 3) for these commands.
