KB88912
Published: July 22, 2020
Revision: 4.0
Milliseconds Since Powerup Value Incorrect
Firmware for:
- GRV-EPIC-PR1
- GRV-R7-MM1001-10
For GRV-EPIC-PR1: 1.5.0 to 2.0.1 (may affect previous versions)For GRV-R7-MM1001-10: All versions prior to 2.0.1
For GRV-EPIC-PR1: 2.0.2For GRV-R7-MM1001-10: 2.0.1
If your GRV-EPIC-PR1 or GRV-R7-MM1001-10 has been powered up for more than 50 days (or possibly as few as 25 days), the 64-bit milliseconds since powerup value at OptoMMP memory map address 0xF030 0228 will be incorrect. The value will be much too high.
