KB88907
Published: May 5, 2020
Restore fails if Node-RED is disabled before power cycle
Firmware for GRV-EPIC-PR1
All versions to .1.5.0
2.0.0
In groov Manage, if you disabled Node-RED (Home > Node-RED > Disable), then cycle power on your GRV-EPIC-PR1, and then try to restore a backup (Home > Maintenance > Restore), the restore will fail. If you look in the groov Manage error log, you may see a message similar to the following:
[2020-03-23 15:07:52.936] [ERROR] SystemRestore - Could not stop  Node-RED { Error: Command failed: pm2 stop node-red
    at ChildProcess.exithandler (child_process.js:294:12)
    at ChildProcess.emit (events.js:198:13)
    at ChildProcess.EventEmitter.emit (domain.js:448:20)
    at maybeClose (internal/child_process.js:982:16)
    at Process.ChildProcess._handle.onexit (internal/child_process.js:259:5) killed: false, code: 1, signal: null, cmd: 'pm2 stop node-red' }
Enable Node-RED (Home > Node-RED > Enable) and try the restore again (Home > Maintenance > Restore).
