KB88905
Published: May 11, 2020
S1 or S2 controller in a redundant system shows "non-qualified" when using persistent timer variables
Firmware for:
  • SNAP-PAC-S1
  • SNAP-PAC-S1-FM
  • SNAP-PAC-S1-W
  • SNAP-PAC-S2
  • SNAP-PAC-S2-W
Firmware R9.0a to current, until fixed
In a redundant SNAP PAC controller system (using the SNAP-PAC-ROK), the PAC Redundancy Manager reports that the backup controller is "non-qualified" instead of "qualified." This issue occurs when using persistent timer variables.
Use only timer variables that are not persistent.
