KB88892
Published: May 5, 2020
GRV-EPIC-PR1 may lock up while running certain Node-RED nodes
Firmware for GRV-EPIC-PR1
All versions to .1.5.0
2.0.0
You may observe lock-up symptoms like the following:
- GRV-EPIC-PR1 is unresponsive.
- The LEDs on groov I/O modules all turn red.
- Ethernet communication ceases.
If the
groov EPIC processor is running Node-RED flows when these symptoms appear, it's possible that a third-party node installed on your processor has a memory leak. To determine if this might be the cause of these issues:
- Log into your groov EPIC processor with an ID that has administrator privileges.
- From the groov Manage Home page, click Node-RED.
- Record the value on the Memory Usage field.
- Wait 24 hours.
- Return to the groov Manage Node-RED page (steps 1 and 2).
- Compare the value in the Memory Usage field with the value you recorded from step 3.
If the difference is significant, there may be a memory leak that is causing your GRV-EPIC-PR1 to display "lock-up" symptoms.
Monitor Node-RED memory usage. If it starts to increase above typical, then restart Node-RED.
