KB88872
Published: May 5, 2020
"Send Email with Attachments" command may not send attachment
Firmware for GRV-EPIC-PR1
All versions to .1.5.0
2.0.0
When using the PAC Control command “Send Email with Attachments” in a strategy running on a GRV-EPIC-PR1, if you use the “~/” path shortcut as part of the location of the attachment, the attachment will not be sent.
Instead of using “~/”, use "/home/user/”. For example, "/home/user/unsecured/2020-02-DayTotal.csv".
