KB88856
Published: May 5, 2020
No network access through OpenVPN Tunnel 0 interface
Firmware for GRV-EPIC-PR1
1.4.0 to 1.5.0
2.0.0
If you established a connection to an OpenVPN server, and then lose communication to that server, when the issue causing the loss of communication is resolved (as verified by the following symptoms), you may not be able to access the Internet:
- You see the port lights flickering green, indicating network activity.
- In groov Manage, when you check on the Network page (from the Home page, click System > Network), the OpenVPN Tunnel 0 section and corresponding Ethernet sections (Ethernet 0 or Ethernet 1) show that they are connected.
Cycle power on the GRV-EPIC-PR1.
