KB88854
Published: May 11, 2020
SNAP PAC Controller in Redundant System May Reset When Viewing Errors in Message Queue
Firmware for:
  • SNAP-PAC-S1
  • SNAP-PAC-S1-FM
  • SNAP-PAC-S1-W
  • SNAP-PAC-S2
  • SNAP-PAC-S2-W
All firmware versions
This issue applies only to a redundant system using S-series controllers and the SNAP-PAC-ROK.
If a strategy for a controller in a redundant system contains a pointer of type Generic I/O Unit, but the I/O unit it is pointing to is not a generic I/O unit, running the strategy may cause errors. When you try to view errors in the message queue, the controller may reset.
