KB88852
Published: May 5, 2020
MQTT service not reconnecting
Firmware for GRV-EPIC-PR1
1.4.0 to 1.5.0
2.0.0
On the GRV-EPIC-PR1, if there is an interruption in network connectivity with the MQTT broker, when network connectivity is re-established, the MQTT service does not reconnect. What you may see is:
  • Tags are shown as not updated.
  • You are able to connect to the GRV-EPIC-PR1 through other means (for example, by logging into it with groov Manage).
In groov Manage, restart the MQTT service.
