KB88831
Published: March 9, 2022
PAC Control "Open Outgoing Communication" command does not create directory; returns -417 error
Firmware for the following:
GRV-EPIC-PR1: All versions prior to 2.0.2
SoftPAC: All versions prior to R10.4d
GRV-EPIC-PR1: 2.0.2
SoftPAC: R10.4d
When using the Open Outgoing Communication command with a file communication handle, it will return a -417 error if the directory path in the communication handle does not already exist. For example, file:w, C:\logs\examplelog.txt
returns a -417 error if the C:\logs directory does not already exist.
Create the directory outside of the strategy.
