KB88804
Published: July 22, 2020
Large Arrays Written to Numeric Tables Incorrectly
Firmware for GRV-EPIC-PR1
1.5.0 to 2.0.1
2.0.2
When you write a large number of elements (greater than approximately 100) to a numeric table with either of the following methods, the elements may be written in the incorrect order and some of the values may repeat:
- PAC Control REST API: POST method to a table
- Node-RED for PAC Control: pac-write node that writes elements to a table
Write smaller groups of table elements (less than 100).
