KB88799
Published: March 16, 2020
Add/Edit User Page incorrectly shows "PAC Control REST API" permission as NONE
Firmware for GRV-EPIC-PR1
All versions
In groov Manage, when you view a System-Wide Administrator user (from the Home page, click Accounts, then select a System-wide Administrator), it incorrectly shows the "PAC Control REST API" (or "Control Engine REST API") permission as NONE. This text is incorrect: system-wide administrators do have permission to use the PAC Control REST API.
