KB88789
Published: July 22, 2020
Move I/O Unit to Numeric Table [Ex] Commands May Not Retrieve All Analog Inputs/Outputs
Firmware for GRV-EPIC-PR1
All versions prior to 2.0.2
2.0.2
With the following two commands, some or all analog input/output values may not be stored to the destination table:
  • Move I/O Unit to NumericTable
  • Move I/O Unit to NumericTable Ex
This does not occur on the initial download of a strategy; however, if changes have been made to the strategy, it may occur on subsequent downloads.
Prior to downloading a modified version of the strategy, do the following steps:
  1. Clear the control engine's RAM with either of the following methods:
    • In PAC Control Debug mode, click Control Engine > Clear RAM.
    • In PAC Terminal, right-click the controller and select "Clear Control Engine RAM".
  2. Download and run the strategy.
