KB88780
Published: March 17, 2020
Writing NaN (Not A Number float value) to analog output is not ignored
Firmware for GRV-EPIC-PR1
All versions
Writing NaN (Not A Number float value) to an analog output should be ignored. However, this issue causes the following:
  • In PAC Control, when you read the analog output, you'll see 1.#QNAN.
  • In groov Manage, you'll see "Invalid Value."
However, the analog output value is not changed, which is the correct behavior.
Ensure that the floating-point value is valid before writing it to an analog output.
