KB88763
Published: March 13, 2020
MQTT topics not being published from OptoMMP device
Firmware for GRV-EPIC-PR1
1.5.0 to current
If you observe either of the following:
  • MQTT had been publishing tags (in either a Sparkplug or string payload) from the PR1’s I/O channels (when the MQTT Service’s device type is set as OptoMMP)OptoMMP and then stopped.
  • When you try to find public tags from an OptoMMP device, you can't find any.
Check for the following:
  • Was the I/O module on the chassis switched from an analog or discrete module to a serial or CAN module? (Switching between analog and discrete does not cause the previously mentioned symptoms.)
  • Is the control application configuring I/O on an OptoMMP device incorrectly (for example, mapping a channel incorrectly) or writing to a non-existent channel?
Review channel configurations to ensure that they map to appropriate I/O modules installed on the chassis and of the correct type.
