KB88679
Published: November 22, 2019
Connection or communication errors with Data Simulator and System Devices
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
R1.3.0 to current for GRV-EPIC-PR1
R4.1a to current for all others listed
In groov View, your project accesses gadgets configured with both Data Simulator and System tags at the same time (normally because they are on the same page), your project may fail to communicate or connect to either or both. You'll see a sequence of messages similar to the following:
Nov 7, 2019 9:09:26 AM INFO com.opto22.groov.scanner.core.DeviceController - Connecting to device Simulator-1
Nov 7, 2019 9:09:26 AM INFO com.opto22.groov.scanner.core.DeviceController - Connected to device Simulator-1
Nov 7, 2019 9:09:26 AM WARN com.opto22.groov.scanner.core.DeviceController - An unknown error occurred while communicating with device System-1.
Note that the device that these messages indicate
groov View is trying to connect to switches from Simulator-1 to System-1.
