KB88665
Published: November 22, 2019
Length field in I/O Unit Tag editor always displays 0x10
groov View running on:
- GROOV-AT1, GROOV-AT1-SNAP
- GRV-EPIC-PR1
R1.3.0 to current for GRV-EPIC-PR1
R4.1a to current for all others listed
In groov View, when you edit a previously configured tag, the Length field displays 0x10. It saves the value correctly, but displays the wrong value.
When you edit the tag, type in the correct value.
