KB88663
Published: November 22, 2019
Gadgets show "could not connect to the controller" message
groov View running on:
- GRV-EPIC-PR1
- GROOV-AT1, GROOV-AT1-SNAP
R1.3.0 to current for GRV-EPIC-PR1
R4.1a to current for all others listed
If your groov View project has an I/O Unit device and contains gadgets configured to access a memory map address that is not 4-byte aligned, after groov View tries to access that address, it displays yellow triangles for any gadget connected to that I/O Unit device. If you click on the triangle, groov View displays the following message:
Could not connect to the controller. groov will keep trying to connect.
Details: An unknown error occurred while communicating with device OptoMMP@<address>:<port>.
Where
<address>
and
<port>
are the IP address and port number of your controller.
If you can, avoid configuring gadgets that access tags with addresses that can't divide evenly by 4.
