KB88655
Published: December 18, 2019
Some MQTT String Payload Values Don't Publish
Firmware for GRV-EPIC-PR1
1.4.1 to 1.4.4
1.5.0
If you have GRV-EPIC-PR1 configured to publish through MQTT Service with string payloads, floating point values that are “not a number” (NaN) do not publish.
Avoid generating NaN values by:
  • Ensuring the input signal is within measurement limits.
  • The modules are online and properly functioning.
