KB88649
Published: December 18, 2019
CODESYS: "Opening Ethernet Adapter Failed" Error with CODESYS PROFINET Controller SL
Firmware for GRV-EPIC-PR1
R1.3.0 to 1.4.4
1.5.0
In CODESYS Development System, after you download your application, the log contains an "Opening Ethernet Adapter Failed" error and the application can not communicate with Profinet I/O.
