KB88608
Published: July 22, 2020
Get and Restart Measurement Commands Don't Restart Measurement Correctly
Firmware for GRV-EPIC-PR1, along with the firmware for the following modules:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDC-24
  • GRV-IDCI-12
  • GRV-IDCIFQ-12
  • GRV-IDCSW-12
For GRV-EPIC-PR1: All versions prior to 2.0.2
For modules listed: All versions prior to 2.0.2
2.0.2
The following PAC Control commands are supposed to restart the measurement at the start of the next pulse or period:
  • Get & Restart Off-Pulse Measurement
  • Get & Restart On-Pulse Measurement
  • Get & Restart Period
However, with this issue, if an on-pulse, off-pulse, or period is in progress, these commands do not restart the measurement at the start of the next pulse or period; the command continues to measure the current pulse or period.
You will notice this issue when you run the commands with channels on the following modules:
  • GRV-IAC-24
  • GRV-IACDCTTL-24
  • GRV-IACHV-24
  • GRV-IACI-12
  • GRV-IACIHV-12
  • GRV-IDC-24
  • GRV-IDCI-12
  • GRV-IDCIFQ-12
  • GRV-IDCSW-12
Before a Get and Restart command, ensure that the current pulse or period is complete with the appropriate command:
  • Get Off Pulse Measurement Complete Status
  • Get On Pulse Measurement Complete Status
  • Get Period Measurement Complete Status
