KB88606
Published: November 7, 2019
Strategy loaded from microSD card will not autorun
Firmware for:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
R10.0d through current
In a PAC Control strategy with the Autorun flag set, after you power up the controller with the strategy loaded from microSD card, the strategy does not autorun.
Do either of the following:
- Load the strategy from flash instead of microSD card.
- After powering up the controller and loading the strategy from the microSD card, in PAC Control Debug mode, manually start the strategy.
