KB88599
Published: October 17, 2019
Errors or abnormal functioning with channels on GRV-IDCIFQ-12 module
R10.2a to R10.2b
R10.2c
In PAC Control, if you configure a channel on a GRC-IDCIFQ-12 module with a feature other than None or Quadrature Counter, commands related to the feature will result in an error in the controller's message queue and/or abnormal functioning. For example, using the Get & Restart Off-Pulse Measurement command will result in an "Invalid data" error in the controller's message queue.
