KB88597
Published: May 5, 2020
Move Numeric Table to I/O Unit (and Ex) commands do not work with pointer tables
Firmware for GRV-EPIC-PR1
1.4.0 to 1.50
2.0.0
In PAC Control, if you specify a pointer table as the source for the Move Numeric Table to I/O Unit
and Move Numeric Table to I/O Unit Ex
commands, the command will have no effect.
Specify a numeric table as the source for the Move Numeric Table to I/O Unit
commands.
