KB88528
Published: October 14, 2019
groov I/O: TPO may not update percent on-time (duty) correctly
Firmware for GRV-EPIC-PR1
All versions prior to 1.4.3
1.4.3
If your PAC Control strategy runs a Set TPO Period command followed by Set TPO Percent command, you may observe that the TPO period is cut short or extended for one period. This should not happen; any changes to the cycle should take effect at the boundary of a period so as not to cut short or extend a period.
Note: To resolve this issue, you must also apply updated firmware to some groov output modules as described in KB88434.
