KB88518
Published: September 25, 2019
MQTT topics not being published
Firmware for GRV-EPIC-PR1
1.4.1
1.4.2
If you are running MQTT with string payloads on your groov EPIC processor and you did not specify a base topic, your topics (PAC Controller tags) will not be published. The base topic is required; however, the groov Manage interface indicates that the base topic is optional.
Provide a base topic in the MQTT Base Topic field of the Sparkplug page (from groov Manage Home, click Sparkplug). (To view the MQTT Base Topic field, enable the Plain MQTT Protocol.)
