KB88503
Published: September 25, 2019
"publishall" topic doesn't publish all tags
Firmware for GRV-EPIC-PR1
1.4.1
1.4.2
If you are running MQTT with string payloads on your groov EPIC processor and you publish the special "publish all" topic (for example, mqttbasetopic/special/myGroupId/myEdgeNodeId/deviceId/publishall), all tags should be published. However, the processor publishes only the "status" tags.
