KB88490
Published: October 17, 2019
OptoDataLink: Data links do not start
All versions prior to R10.2c
R10.2c
When the play button or menu item Run > Start all links is selected, the data links do not start. No errors are reported in the OptoDataLink Error log.
The problem occurs when the OptoDataLink project file is stored on a network drive. If the project file is saved on the local drive, the problem does not occur.
Save the OptoDataLink project file on the local drive.
