KB88449
Published: August 9, 2019
Modbus/TCP does not report a cleared latch as cleared
GRV-EPIC-PR1
All versions
If you clear an On and/or Off Latch through Modbus/TCP, it does not properly report the latch as cleared; however, groov Manage and the channel inspect window in PAC Control Debug Mode do show the latch as cleared.
If you are not limited to using Modbus/TCP, then try any of these options:
  • groov Manage. From the Home page, click I/O, select the module, select the channel, then click Clear for either On-Latch or Off-Latch.
  • PAC Control. In Debug Mode, open an inspect window for the channel to clear or read the channel.
  • Directly access memory map base address 0xF02E0000 to clear the latches and memory map base address 0xF01E0000 to read the latches.
