KB88418
Published: November 4, 2019
Cannot enable communication to groov I/O unit
Firmware for GRV-EPIC-PR1
Firmware for:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
All versions prior to 1.4.0 for GRV-EPIC-PR1
Version 10.0d or newer for SNAP-PAC/SoftPAC controllers
If either of the following conditions occur after a PAC Control strategy has run, the control engine will not be able to enable communication to the affected groov I/O Unit and a -93 (I/O Unit Disabled) error will be posted to the control engine’s message queue:
  • Power is cycled on a remote groov I/O unit.
  • You Reset I/O to Defaults using groov Manage (Home > I/O > I/O Unit Configuration and Tools > Configuration > Reset I/O to Defaults)
Note: This issue does not occur the first time the PAC Control strategy is run after downloading the strategy to the control engine.
Clear control engine RAM and then download the strategy again.
