KB88391
Published: September 25, 2019
I/O unit's Inspect window incorrectly reports channel quality as good for missing module
Firmware for GRV-EPIC-PR1
1.2.0 to 1.4.1
1.4.2
If you have a channel configured in a PAC Control strategy but the module is not installed on the chassis, when you run the strategy in Debug Mode and view the channel through the Points [Detailed] tab of the I/O unit's Inspect window, the quality shows Good. It should show Bad.
