KB88375
Published: August 20, 2019
Control Engine not responding when Ethernet cable disconnected, then reconnected
Firmware for GRV-EPIC-PR1
1.3.2
1.4.0
If you disconnect and then reconnect the Ethernet cable from the GRV-EPIC-PR1, the GRV-EPIC-PR1 may stop communicating on its host port. However, you can still access the GRV-EPIC-PR1 with groov Manage.
After the issue occurs, the easiest and quickest way to recover is by using groov Manage to disable and then re-enable the control engine.
