KB88363
Published: August 20, 2019
Revision: 5.0
All OPC UA and Allen-Bradley devices disconnect and become unresponsive
- groov Admin on GROOV-AR1, GROOV-AR1-BASE, GROOV-AR1-SNAP
- Firmware for GRV-EPIC-PR1
1.570.50 of groov Admin
1.0.0 to 1.3.2 of GRV-EPIC-PR1
1.570.51 of groov Admin
1.4.0 for GRV-EPIC-PR1
Ignition Edge v7.9.10 has a bug in the OPC-UA and Allen-Bradley® modules that can cause a sync write timeout which causes all OPC UA and Allen-Bradley devices to be disconnected and unresponsive. You can find more information about the fix to this bug in the release notes for Ignition Edge 7.9.11, under the Allen-Bradley Driver section.
