KB88311
Published: October 17, 2019
PAC Display Configurator: Graphic Dynamic Attributes lets you select Fixed data Toggle when source is Prompt for data
PACDISPLAYBAS (PAC Display Basic)
PACDISPLAYPRO (PAC Display Pro)
All versions prior to R10.2c
R10.2c
In PAC Display Configurator's Graphic Dynamic Attributes dialog box, you can choose from two source options: fixed data and prompt for data. If you choose Prompt for data, the dialog box still allows you to select the Fixed Data Toggle button.
