KB88298
Published: October 17, 2019
With Redundant Network System Type, secondary IP address not used when set to active
PAC Control Professional
R10.0a to R10.2b
R10.2c
For a PAC Control Engine configured with a System Type of Redundant Networks, if you set the Secondary IP Address as the active IP address (in PAC Control, right-click the control engine, then select "Use Secondary IP Address"), when in Debug mode, you could see any of the following behavior:
- In PAC Control, select Control Engine > Inspect. The top of the inspect window shows that the control engine's primary IP address is being inspected, not the secondary IP address.
- If you unplug the Ethernet cable from the Ethernet 1 port, PAC Control displays a timeout message.
