KB88297
Published: October 17, 2019
With Redundant Network System Type, secondary IP address not used when set to active
PAC Terminal
R10.0a to R10.2b
R10.2c
In PAC Terminal, if you right-click on a control engine with a System Type of Redundant Networks, then select Use Secondary Address, you'll see that in the Control Engines list, the control engine will list the primary IP address under the Address 2 column. In addition, when you click View Status, the Inspect window will show the primary IP address as the control engine's IP address, indicating it is accessing the control engine through the primary address. (It should show the secondary IP address.)
