KB88280
Published: August 22, 2019
Not Equal? condition always evaluates as true
Firmware for GRV-EPIC-PR1
1.3.2
1.4.0
The PAC Control condition Not Equal? always evaluates as true when evaluating an analog input or float variable whose value is NAN (not a number, which is an invalid float value). The condition works correctly for integer variables.
Use the "Float Valid?" instruction before doing the comparison.
