KB88125
Published: June 14, 2019
PAC Display Runtime: Recipe upload hangs
PAC Display Runtime
All versions prior to R10.2b
R10.2b
If you have PAC Project with a recipe upload, when then recipe upload runs, the "Uploading" message might not go away, and the upload doesn't complete. This is more likely to happen if the recipe upload is in a window that contains tags that are updated frequently and the recipe file has many large tables.
Repeat the recipe upload until it completes successfully.
