KB88190
Published: November 7, 2019
Erratic behavior when running PAC Control strategy
Firmware for:
  • SNAP-PAC-S2, SNAP-PAC-S2-W
  • SoftPAC
R10.0a through current
You may observe erratic behavior (like those listed below) if your PAC Control strategy contains logic that passes a pointer table as a parameter to a subroutine:
  • Strategy logic does not perform correctly
  • Controller resets
Modify the logic in your PAC Control strategy to pass a pointer instead of a pointer table to a subroutine.
