KB88179
Published: June 14, 2019
PAC Control: View I/O Units dialog flickers while in Debug mode
All versions prior to R10.2b
R10.2b
When in PAC Control Debug mode, if you open the View I/O Units dialog box, the dialog box flickers when the Debugger Performance is set to Medium or High. The flickering makes it difficult to view the information in the dialog box.
Set the Debugger Performance to Low.
