KB88155
Published: July 18, 2019
Network and Firewall settings may not be restored after update
Firmware for GRV-EPIC-PR1
All versions
If you selected the "Back Up Network" option when you started an update, the backup may fail. When the GRV-EPIC-PR1 finishes the update and you check your network and firewall settings, they are the defaults.
