KB88148
Published: February 25, 2020
PAC Control Calculate Strategy CRC command may return wrong value
Firmware for:
- SNAP-PAC-S2, SNAP-PAC-S2-W
- SNAP-PAC-R1, SNAP-PAC-R1-FM, SNAP-PAC-R1-W, SNAP-PAC-R1-B
- SoftPAC
All versions prior to R10.0h
R10.0h
In a PAC Control strategy, if the Calculate Strategy CRC
command is used in Block 0 of the Powerup chart and then again after a subroutine has been called, the two values may differ.
If your PAC Control strategy contains logic that passes a numeric value to a subroutine as a literal, change those instances to pass the numeric value as a variable.
