KB88135
Published: August 22, 2019
Changing controller's string encoding doesn't take effect immediately
groov View running on GRV-EPIC-PR1
1.3.0 through 1.3.2
1.4.0
If you change the controller's string encoding, the change doesn't take effect immediately. (To change the string encoding, in Build mode, click Configure > Devices and Tags, select your controller, click Edit Device, select a different value for String Encoding, click Update Device.)
Restart groov View to make the changes take effect.
