KB88014
Published: August 20, 2019
Downgrading firmware may cause firewall rules to revert to defaults
GRV-EPIC-PR1
1.2.0 to 1.3.2
1.4.0
In the following combination of circumstances, the firewall rules will revert to factory defaults:
  • You are downgrading firmware versions.
  • Before starting the firmware update, you select the option to automatically back up and restore firewall rules.
  • The firewall rules in the firmware version you're downgrading from contain ports that were reserved in the default rule set of the firmware version you're downgrading to.
If you are starting from 1.4.0 or newer and you are downgrading to 1.3.2 or earlier, remove UDP and TCP rules for ports 8502, 22006, and 22007.
