KB87962
Published: October 17, 2019
PAC Display Configurator becomes unresponsive when Runtime Setup > Define Default is selected
R10.0a to R10.2b
R10.2c
PAC Display Configurator becomes unresponsive after you click Runtime Setup > Define Default. You can't get out of PAC Display except by using Ctrl-Alt-Delete.
This problem only occurs using the new Dynamic Attributes Dialog. If the older style dialogs are used, it does not occur.
Use the older style Dynamic Attribute Dialogs instead (File > Configurator Options > Use Older Dynamic Attribute dialogs).
