KB87872
Published: April 17, 2019
In PAC Control, configuring groov EPIC as an I/O unit with both IP addresses configured may cause strategy download to fail
Firmware for:
- GRV-EPIC-PR1
- SNAP-PAC-S1
- SNAP-PAC-S1-FM
- SNAP-PAC-S1-W
- SNAP-PAC-S2
- SNAP-PAC-S2-W
- SNAP-PAC-R1
- SNAP-PAC-R1-FM
- SNAP-PAC-R1-W
- SNAP-PAC-R1-B
- SNAP-PAC-R2
- SNAP-PAC-R2-FM
- SNAP-PAC-R2-W
- SOFTPAC
PAC firmware: R10.0d
GRV-EPIC-PR1: All versions prior to 1.3.1
PAC firmware: R10.0f
GRV-EPIC-PR1: 1.3.1
If you configure groov EPIC as an I/O unit in PAC Control, and you also configure both its Ethernet network interfaces (ETH0 and ETH1), the strategy may fail to download.
When configuring the GRV-EPIC-PR1 as an I/O unit in PAC Control, do not configure the optional Secondary IP address (ETH1).
