KB87769
Published:
The arbiter stops functioning after about 24 days
Firmware for SNAP-PAC-SRA
R9.1c and earlier
R9.1d
If you are running a system with the SNAP PAC Redundancy Option Kit, the arbiter will stop functioning after about 24 days. The arbiter's serial TX LEDs will stop flashing and Redundancy Manager's "Status (via arbiter)" may not show any errors.
Try either of the following:
  • From PAC Manager, issue the "Restart Device from powerup" command
  • Cycle power to the arbiter.
